12-09-2019 03:35 AM - edited 02-21-2020 11:12 AM
What is the difference between 1 and 2
1)
aaa authorization commands default group tacacs+ none
2)
aaa authorization commands 0 default group tacacs+ local aaa authorization commands 10 default group tacacs+ local aaa authorization commands 15 default group tacacs+ local
Solved! Go to Solution.
12-12-2019 03:57 PM
Maybe a picture helps
Having said all that, the aaa accounting is still seen in ISE Command for all priv levels, even though I (thought I) told it to only log commands for users with level 15 - I wonder what is going on there?
12-10-2019 01:20 PM
Option 1 will use TACACS+ to authorize every command, and at any EXEC level (0-15)
Option 2 will use TACACS+ for those specific EXEC levels only (and not for others)
12-11-2019 09:28 PM
Thanks for the reply
Can you explain little bit with example
12-12-2019 03:57 PM
