09-12-2018 08:20 AM
What is the recommendation if a customer wants to limit access to the self-reg BYOD portal based on AD Groups? i.e. staff and contractors get access to self register devices, but no one else can access the portal....
Solved! Go to Solution.
09-12-2018 09:53 AM
09-12-2018 09:33 AM
You have to use the RADIUS callback trick documented on the forums. Basically setup ISE as a RADIUS server to itself which allows the flow to come into a normal policy set where you can apply AD restrictions.
09-12-2018 09:53 AM
