Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
122
Enthusiast
Adding a Device Admin License on top of a Mobility License
I had a question. I remember in ISE past that with the mobility license we could not add standard switches to the deployment. This is rightfully so as the use case for the mobility license is VPN and Wireless Only. My question is around adding a TACACS+ license to the Mobility deployment. I know per the license guide this is possible but my customer would like to use TACACS+ on their wired switches in the mobility deployment. I think that would work fine but I wanted to double check.
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: Adding a Device Admin License on top of a Mobility License
You are correct. The Mobility license's not allowing "wired" auth is for RADIUS only so has no impact on T+.
Regards.
2 REPLIES 2
Regards.
Highlighted
Enthusiast
Cool Thanks!
