ISE 2.3 Patch 7 has been posted. This will be the last patch for the ISE 2.3 release!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
1065
Highlighted
Contributor
AnyConnect NAM questions
Greetings,
Just a couple questions to see if there is any fix, or just to live with it.
1) AnyConnect NAM increases system boot time by 20+ seconds. I do not use the VPN and use it for EAP-Chaining for ISE. It works, but wonder if there is a fix for the extra boot time.
2) AnyConnect NAM takes over the wireless. This isn't an issue, but if they try to connect using the Windows wireless, it fails. Is there a way to get AnyConnect to take the Windows inputs, or hide the Windows wireless. Basically trying to reduce calls due to people trying the Windows wireless instead of AnyConnect to join a network.
Everyone's tags (4)
1 ACCEPTED SOLUTION
Re: AnyConnect NAM questions
Question 1:
NAM will add a slight delay to the Windows boot/logon times.  Drivers loading, Credential Providers being loaded etc.  I would suggest testing on a clean PC without other 3rd party software and see if you still see the same issue.
Question 2: AnyConnect NAM has a service dependency on WLANAutoConfig service, so disabling it would also disable NAM functionality.  I think the tray icon can be hidden via GPO, or direct registry modification as shown in the other users link.
Notification Area Icons - Hide or Show System Icons and Notifications - Windows 7 Help Forums
I think it can also be done via the registry, but I have not tested.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer
REG_DWORD keyname = HideSCANetwork
5 REPLIES 5
I've not seen AnyConnect adding that much time to boot up Windows but it's probably depending on the hardware.
And, your 2nd one is also the first I've seen. You might try disabling "WLAN AutoConfig" (wlansvc) service.
Contributor
WLAN autoconfig seems to be a dependency of NAM, so can't disable it without also disabling AnyConnect.
Contributor
i have same question"2".
users are confused when they have 2 options to connect.
anyone got some better way to do that ?
Sorry, it's really no go by disabling WLAN autoconfig even on the specific interface with netsh.
Our AC ESC suggested this --> Permanently hide the wireless network icon from the Windows 7 taskbar
There seems possible to do with registry hacks, as discussed @ Where are the System Tray Customizations stored? which leads to Forcing notification area Icons to always show in Windows 7 or Windows 8 - 4sysops
Question 1:
