ISE 2.3 Patch 7 has been posted. This will be the last patch for the ISE 2.3 release!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
224
Highlighted
VIP Advocate
Apache Struts2 vulnerability and future ISE patches
Quick question: will all future ISE patches contain the Struts2 fix that is currently available on CCO? e.g. when ISE 2.4 patch 3 is released, will we need to still apply this Struts2 patch as well, or will it be integrated into patch 3.
thanks
Everyone's tags (4)
1 ACCEPTED SOLUTION
VIP Advisor
Re: Apache Struts2 vulnerability and future ISE patches
Usually new patches are not included in released patches but will be added in the next one.
I believe it'll will be the same for this one unless they decide to do a retrofit
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
1 REPLY 1
VIP Advisor
Francesco
