07-11-2018 11:30 PM
Hi All,
Would it be possible to return a ACL name to be used as 'VPN Filter'?
I know it is possible to return a DACL or Group policy, but I want to return the name of an ACL that is configured on the ASA to be used as the VPN Filter.
Using 'ACL (Filter-ID)' in the authorisation profile does not seem to work.
Thanks for your help!
Solved! Go to Solution.
07-12-2018 12:51 PM
The .in is a directive for "Inbound" ACL and would be interpreted correctly by wired switch. Since ASA not accepting, adding under Advanced attributes to avoid any undesired extensions is correct option.
07-12-2018 08:05 AM
07-12-2018 11:22 AM
Hi Craig,
Originally I tried the filter ID, using the "ACL (Filter-ID)" field in the authorization profile.
This resulted on the following entry:
Access Type = ACCESS_ACCEPT
Filter-ID = MYACLNAME.in
ISE automatically ads the ".in" after the ACL name, resulting in not even passing authentication on Anyconnect
Just a side question: Why the ".in"?
When I manually added the Radius:Filter-ID [11] it works like a charm!
07-12-2018 12:51 PM
