Register for the monthly ISE Webinars to learn about ISE configuration and deployment.
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
470
ASA Anyconnect return ACL/VPN Filter
Hi All,
Would it be possible to return a ACL name to be used as 'VPN Filter'?
I know it is possible to return a DACL or Group policy, but I want to return the name of an ACL that is configured on the ASA to be used as the VPN Filter.
Using 'ACL (Filter-ID)' in the authorisation profile does not seem to work.
Thanks for your help!
Everyone's tags (3)
1 ACCEPTED SOLUTION
Advocate
Re: ASA Anyconnect return ACL/VPN Filter
The .in is a directive for "Inbound" ACL and would be interpreted correctly by wired switch.  Since ASA not accepting, adding under Advanced attributes to avoid any undesired extensions is correct option.
3 REPLIES 3
Hi Craig,
Originally I tried the filter ID, using the "ACL (Filter-ID)" field in the authorization profile.
This resulted on the following entry:
Access Type = ACCESS_ACCEPT
Filter-ID = MYACLNAME.in
ISE automatically ads the ".in" after the ACL name, resulting in not even passing authentication on Anyconnect
Just a side question: Why the ".in"?
When I manually added the Radius:Filter-ID [11] it works like a charm!
Advocate
