08-02-2019 12:54 PM
I installed a 5508-x and created a config which worked with asdm but didn't work properly so I copied an older version and it did work BUT the ASDM doesn't work any more.
I have done the usual troubleshooting according to cisco and the good folks here.
Info:
Old firewall worked asa version 9.1(7) and ASDM ver 7.9.1
New firewall doesn't work asa ver 9.8(2) ASDM 7.9(1)
From my pc, it just spinns.
From the working asdm, Iit does not connect.
Any brilliant minds out there.
HTTP is working
ssl is ok
I'm stumped.
08-05-2019 01:07 PM
08-07-2019 11:08 AM
