Audit Point picks up Tacacs+ Vulnerability
iagyte
Background:
My customer has raised a question based on a vulnerability raised by their security team on TACACS+.  The actual audit point was that there is “no integrity checking available and the use of MD5 encryption
  1. This issue was this raised as part of a security audit
  2. Question relates to using ACS with TACACS+ feature
  3. Software version is based on ACS 5.4
The security team have also referenced - https://supportforums.cisco.com/t5/aaa-identity-and-nac/how-to-secure-tacacs-authentication/td-p/2735412 and there are some very good points made here.
Has anyone else within the ISE community see this before?
Is this the recommendation https://www.cisco.com/c/en/us/support/docs/security/identity-services-engine-22/210519-Configure-ISE-2-2-IPSEC-to-Secure-NAD-I.html
Thanks..
Nidhi
ACS is end of life.
I would suggest upgrading to ISE 2.X and redoing this test.
in any case I will forward this observation to the right team to see if anyone is aware of this .
Nidhi
Nidhi
ACS is end of life.
Nidhi
hslai
Yes, you are correct that customers may consider IPSec to secure the control-plane communications, in case not already protected by another means.
