07-16-2019 07:53 AM - edited 07-16-2019 10:52 AM
hi fellows
can anyone tell me if ise can get some attribute to place nad inside some Identity group automatically?
i have ten different cisco switches models in my campus , and i want to create different policies based on switch model, but automatically , without having to put my swiches in an identity group manually .
Solved! Go to Solution.
07-16-2019 11:33 AM
07-16-2019 11:33 AM
07-17-2019 05:22 AM
Since these are Cisco switches you can customize NAS-ID attribute to reflect switch model and use it in the ISE policy. Please check out 'Differentiating specific network device' section of the following document for more information:
