Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
3354
Highlighted
bandwidth requirements for ISE distributed deployment
Hello everyone,
I'm wondering if we have any official recommendations for the minimum bandwidth between ISE nodes in the distributed deployment?
I know we have latency requirements (< 200 ms) but I couldn't find any official documentation about the bandwidth
Everyone's tags (3)
1 ACCEPTED SOLUTION
Advocate
Re: bandwidth requirements for ISE distributed deployment
With the changes to partner ATP program, it was decided to make this tool available to all partners as well as customers.  To ensure consist versions of posted content, I will delete the version posted to partner community.  Also, I am not sure which version that post was based on due to name change.
The new page for the ISE Bandwidth Calculator can be found here: ISE Latency and Bandwidth Calculators
Notes:
  • Although created for ISE v1.2, the results are applicable to later versions as well.
  • The calculator is intended to provide design guidance based on some key assumptions and actual bandwidth requirements will vary based on deployment and configuration.
  • The tool is not supported by TAC and is provided as-is.
Craig Hyps, Cisco Technical Marketing
4 REPLIES 4
Contributor
This is the most Current version I have been able to find and have been using it. It is for ISE 1.2, but I was told that the bandwidth calculations have not changed.
http://www.ciscosecurityatp.com/filedownloader.asp?ID=108
Cory,
Thanks a lot for your response. But unfortunately I cannot get access to this document... Can you please share it with me directly?
Contributor
I have uploaded it to the community.
108-bandwidth_calculator.xlsm
Advocate
Notes:
