Bootable USB not working for ISE 2.4 image for 3600 appliances
aravikumar
Trying to reimage new 3615 boxes with 2.4 image with new ISO. I followed Cisco doc as it.
https://www.cisco.com/c/en/us/td/docs/security/ise/2-4/install_guide/b_ise_InstallationGuide24/b_ise_InstallationGuide24_chapter_011.html#id_12079
performed step 1 to 10 from above document. After reloading boxes and booting it from USB , I did get notification for below
Cisco ISE Installation (Serial Console)
Cisco ISE Installation (Keyboard/Monitor)
System Utilities (Serial Console)
System Utilities (Keyboard/Monitor)
I chose Cisco ISE Installation (Keyboard/Monitor) but after this I got an error (please see the attached screenshot).
error: /syslinux/vmlinuz has invalid signature. Please help me to resolve this issue.
Aravind
Hi @ccole
Did you upgrade your CIMC by any chance?  ISE uses UEFI Secure Boot and this means it will perform a certificate check against the OS boot sector.  If you use a random version of the UCS C220 CIMC firmware then you will prevent ISE from booting.  The CIMC versions that ISE support are just a few.
6 Replies 6
kthiruve
Please make sure you use the right image. It is looking for signed image that is correct for the appliance.
ise-2.4.0.357.SPA.x86_64_SNS-36x5_APPLIANCE_ONLY.iso
Krishnan
Hi Krishnan,
Thank you for your response.
We are using the right image that is correct for the appliance.
Aravind Ravikumar.
Hello, has this been resolved yet? I have a "errors: /syslinux/vmlinux has invalid signature"
Hi @ccole
Please work with TAC on debugging issues
JHILL2
Had the same issue, and TAC has confirmed that it is a bug.
Bug ID: CSCvq94084
Description: Unable to install 2.4 on 36xx appliance via USB flash Drive
Symptom: ISE 2.4 new ISO using USB flash drive as USB boot installation is faster than vKVM ISO mounting installation, getting below error:
HTH!
error: you need to load the kernel first.
Conditions: ISE 2.4 ISO installation on 36XX via USB flash drive
Workaround: Use vKVM ISO mounting installation (CIMC)
