ISE 2.3 Patch 7 has been posted. This will be the last patch for the ISE 2.3 release!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
147
BYOD - CoA timing difference between Android and Iphone
I'm testing ISE BYOD with iphone/android phone and everything works fine but see some difference below.
For testing purpose, I have 2 AuthZ policy only. (Single SSID, No Certificate provisioning)
Policy1: If BYOD registered device => Internet Only
Policy2: If MSCHAPv2 => BYOD portal with NSP
The difference is below.
1. When testing with Android phone, initial onboarding with 802.1x hit policy2 with redirection and we saw COA was issued when clicking 'Go to Google Play xxxx' in Step 3.
This ultimately made the device hit policy1 again and can connect to the Internet even without finishing NSA. Meaning at this moment, user can access google,youtube etc.
2. When testing with iphone, initial onboarding with 802.1x hit policy2 with redirection and when profile is downloaded in step 3 of 'Apple configuration profile xxxx', there is no COA issued from ISE and hence if user does not complete the profile installation by going back to 'iphone General setting', they will always be redirected since being kept in policy2.
(If I force reconnect to the SSID without installing the profile, the device will hit policy1 and connect to the Internet.)
I understand the policy will not be such open in real-world usecase but want to make sure if this is normal. Is it supposed to see COA when clicking 'Go to Google Play xxx' in usecase 1 above?
4 REPLIES 4
Re: BYOD - CoA timing difference between Android and Iphone
Yes.
We usually add another condition -- Session·Device-OS Equals Android -- in the Policy rule 1.
Hi Hsing Tsu,
Thank you for the response. It's already in there.
The question is when clicking 'Go to Google Play xxxx' in BYOD flow, a COA is seen and we are not sure if it is expected or not.
(We expected the user to go to NSA and complete all the profile download from ISE, then COA is seen to hit policy1).
Highlighted
Likely that COA is after the device is identified as android so you could give it another authorization rule to open up necessary DNSURL rules for the play store
Have you looked at the prescriptive guide under http://cs.co/ise-byod page?
Jason,
I had the same doubts and waited for a while in the screen 'Go to Google Play xxxx'.
If Profiler (identified as android) was the reason of COA, it would be triggered regardless clicking the button 'Go to Google Play xxx' or not.
However COA was not seen as I waited for 1min in that page and as long as clicking it, COA was in.
Let me try to test with turning off the Profiling COA.
