Register for the monthly ISE Webinars to learn about ISE configuration and deployment.
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
61
Catalyst 9200-L Compatibility with ISE 2.0
would like feedback for support of catalyst 9200-L with a stable ISE 2.0 deployment at a customer. I can see it under 2.4 but customer wants to confirm that it will be supported with 2.0.
https://www.cisco.com/c/en/us/td/docs/security/ise/2-0/compatibility/ise_sdt.html#pgfId-55038
https://www.cisco.com/c/en/us/td/docs/security/ise/2-4/compatibility/b_ise_sdt_24.html#supportedciscoaccessswitches
any help or guidance would be appreciated.
1 REPLY 1
Highlighted
VIP Advisor
Re: Catalyst 9200-L Compatibility with ISE 2.0
It will be supported. It uses Radius for communication and there is nothing
specific for the device itself.
