In this Cisco Security Chalk Talks video Imran Bashir, Technical Marketing Engineer, introduces Cisco Identity Services Engine (ISE) Threat-Centric NAC service and its integration with Advance Malware Protection (AMP) and Qualys. This integration enables ISE to take the real time feed from threat severity levels (from AMP) and vulnerability assessment results (from Qualys) and use them to dynamically control the access level of an endpoint or a user on the network. This enables network administrators to restrict access quickly if necessary.
If you have any questions on this content, simply reply to this post and we'll help you out.
* As a CCP member, make sure you are subscribed to all boards (discussions, documents, blogs, videos, and events so you always get the latest information from the program.
