12-11-2018 10:00 PM
When I swap MnT primary/secondary in 2 nodes deployment, usually use role dropdown in deployment nodes menu as follows.
But I notice the operation is not documented in administration guide.
The guide introduce "To convert the existing secondary node to an active primary node, the administrator must first manually promote the secondary node to a primary role." but doen't mention how to do it. (Is something missed? or documented in other places?)
Now I'm creating ISE operational guide to a specific large customer and want to know official way to change monitoring role from ISE GUI. I'd appreciate if dev team confirm if it's official correct way.
Solved! Go to Solution.
12-11-2018 10:33 PM
12-12-2018 05:20 AM
12-16-2018 05:50 PM
That is talking about ISE admin nodes and documented at Manually Promote Secondary PAN To Primary.
For MNTs, the failover is always automatic so usually no need to switch the roles.
You may either log a bug yourself or use the feedback link to send your suggestions.
12-11-2018 10:33 PM
12-11-2018 11:20 PM
12-12-2018 05:20 AM
12-16-2018 05:50 PM
12-16-2018 06:09 PM
Thanks for the comment! Promote to primary MnT is sometimes required for scheduled report exporting. And also sometime TAC suggest swapping primary/secondary for problem isolation or solution.
The bug has been filed with Surendra approval but your comment is also appreciated.
