Change MnT Role
masyamad
When I swap MnT primary/secondary in 2 nodes deployment, usually use role dropdown in deployment nodes menu as follows.
But I notice the operation is not documented in administration guide.
https://www.cisco.com/c/en/us/td/docs/security/ise/2-4/admin_guide/b_ise_admin_guide_24/b_ise_admin_guide_24_new_chapter_011.html#ID95
The guide introduce "To convert the existing secondary node to an active primary node, the administrator must first manually promote the secondary node to a primary role." but doen't mention how to do it. (Is something missed? or documented in other places?)
Now I'm creating ISE operational guide to a specific large customer and want to know official way to change monitoring role from ISE GUI. I'd appreciate if dev team confirm if it's official correct way.
3 Accepted Solutions
Francesco Molino
The way to promote the secondary monitoring node as primary is to use the drop down menu as you showed on your screenshot.
There's no other way I'm aware of.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Seems like a miss. Please work with TAC to get the document modified.
hslai
That is talking about ISE admin nodes and documented at Manually Promote Secondary PAN To Primary.
For MNTs, the failover is always automatic so usually no need to switch the roles.
You may either log a bug yourself or use the feedback link to send your suggestions.
5 Replies 5
Francesco Molino
Francesco
Thanks for the reply. I also think so, but now no official document seems not to mention about the operation. I need Cisco dev team's confirmation if it's officially supported or not.
hslai
Thanks for the comment! Promote to primary MnT is sometimes required for scheduled report exporting. And also sometime TAC suggest swapping primary/secondary for problem isolation or solution.
The bug has been filed with Surendra approval but your comment is also appreciated.
