02-22-2019 07:56 AM - edited 03-08-2019 07:13 PM
I am looking for building an HA solution for Checkpoint identity collector and I was thinking of configuring:
Two Checkpoint identity collectors with each having two pxgrid nodes, so 4 PXGs but it is only supported on v2 pxGrid.
Do someone know if Checkpoint identity collector is v1 or v2 ? If v1 only, will it work in active standby if we use 4 PXG nodes?
Solved! Go to Solution.
02-24-2019 03:47 PM
Checkpoint was developed using pxGrid 1.0. You can only have 2 pxGrid nodes in an Active/Standby scenario per ISE deployment.
John
jeppich@cisco.com
02-23-2019 11:01 AM
02-23-2019 03:42 PM
02-25-2019 05:48 AM
02-24-2019 03:47 PM
John
jeppich@cisco.com
02-25-2019 05:50 AM
02-25-2019 06:56 AM
Yes, Active/Active is only supported in pxGrid ver 2.0.
John
jeppich@cisco.com
