Cisco ISE 1.4.0.253 & MS AD 2019
PedroDias1994
Is it possible to integrate Cisco ISE 1.4.0.253 and MS AD 2019 with functional level 2016? If not, which version of ISE is compatible with MS AD 2019?
Thank you for your help :)
#Mat
Level 6
Level 6
#Mat
Level 6
Level 6
Hi, ISE 1.4 isn't compatible with AD 2109
https://www.cisco.com/c/en/us/td/docs/security/ise/1-4/compatibility/ise_sdt.html#pgfId-87595
For upgrade, the current suggested version of ISE is 2.4 which is compatible
https://www.cisco.com/c/en/us/td/docs/security/ise/2-4/compatibility/b_ise_sdt_24.html#externalidstores
Regards.
HTH.
Thank you Mat for your help :)
