Choose one of the topics below for resources to help you on your journey with ISE
For production deployment issues, please contact the TAC!
We will not comment or assist with your TAC case in these forums.
369
Beginner
Cisco ISE 2.3 No logging in web GUI
We're having issues with Cisco ISE not showing any logs in web GUI. The logs show up in 'Show logging' CLI, but it doesnt seem to present itself to the GUI.
We have a 2 node cluster, with roles split.
The issue started while on 2.1. The admin node went down, and was down for 3 days, no hands on support so we decided to promote the node thats up to admin. Once the first node was brought online, we promoted it back to admin node, and that when our logging issue started. Opened up TAC and was told to install patch 5, but that didnt fix issue, then was told to upgrade to 2.3 and install patch 1, and that still didnt resolve our issue. We're running ISE right now without logging - it's like flying blind.
Any ideas one what i can do? Logging works, we're just not seeing in on the web guiISE home page.JPGtacacs logs.JPGno live logs.JPG
Let me know if you need any information.
Thanks in advance guys!
Everyone's tags (2)
1 ACCEPTED SOLUTION
Highlighted
Re: Cisco ISE 2.3 No logging in web GUI
Would recommend you go to the TAC and escalate if the issue is not being resolved.
Highlighted
Beginner
Wanted to see if any from the community has had this issue and resolved it. I currently have a TAC case opened as mentioned above - it's also at the highest escalation i can get it to right now. It's been opened for a whole month now with no resolution yet. Im also not looking to refresh the ISE nodes - thats not an option.
ok understood, please do escalate to a duty manager if not going anywhere, ask them for a case with the BU if you don't already have one
If you would like us to review your case, please provide the TAC case number. Thanks.
Ask the Expert- Webex Hybrid Services Solutions
