Cisco ISE 2.4 BYOD integration with Meraki
nathant
I am interested in configuring Cisco ISE 2.4 BYOD and integrating it with my Meraki MX84, MS320 and MS225 switches and my MR42 Access Point (AP).
I would ideally like to set up a Dual SSID scenario with an isolated "Guest" network (going through the ISE 2.4 on-boarding process) and then automatically connect to the "Authorised" network when permitted by the ISE policies.
I am hoping to use the DHCP and wireless features on the Meraki appliances and enable a Guest redirect to ISE 2.4 .
I have read there is some limitations with integrating ISE to Meraki, and I was hoping to get some more information on if my scenario would be technically possible?
Jason Kunst
Jason Kunst
Did you follow the meraki ise how to guide on our design integration guide site?
https://community.cisco.com/t5/security-documents/ise-design-amp-integration-guides/ta-p/3621164
