Cisco ISE 2.4 - CSCvq17464
baker82
Do we know if this bug is fixed in ANY of the 2.4 or 2.6 patches?
I see that ISE 2.3 patch 7 resolved this.
Otherwise i may need to look into down grading from 2.4 to 2.3...
Jason Kunst
Please work through TAC if critical to get a hot patch if possible. There is no downgrade option. You’d have to install and configure 2.3 from scratch
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvq17464
Jason Kunst
Worked with TAC to obtain hot patch to resolve issue.
thank you
