Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
89
Beginner
Cisco ISE NIC Bonding
Is it necessary to deregister ISE node from deployment if i want to do NIC Bonding ( eth0 and eth1)?
If i must deregister node, is there a consequences in configuration after i register node to deployment again?
I have two ISE nodes in deployment, primary and secondary.
1 ACCEPTED SOLUTION
Highlighted
VIP Advocate
Re: Cisco ISE NIC Bonding
Nope - I tried it just now and it didn't mind that the node I was doing this on, was in fact the Primary (i.e. it was not a Standalone node).
interface GigabitEthernet 0
  ip address 192.168.0.220 255.255.255.0
  ipv6 address autoconfig
  ipv6 enable
interface GigabitEthernet 1
  shutdown
  ipv6 enable
ise02/admin# conf t
Enter configuration commands, one per line.  End with CNTL/Z.
ise02/admin(config)# interface gigabitEthernet 0
ise02/admin(config-GigabitEthernet)# backup interface gigabitEthernet 1
Changing backup interface configuration may cause ise services to restart.
Are you sure you want to proceed? Y/N [N]: Y
Stopping ISE Monitoring & Troubleshooting Log Processor...
PassiveID WMI Service is disabled
After a few minutes
  ipv6 enable
  backup interface GigabitEthernet 1
And
ise02/admin# show interface
bond0: flags=5187<UP,BROADCAST,RUNNING,MASTER,MULTICAST>  mtu 1500
        inet 192.168.0.220  netmask 255.255.255.0  broadcast 192.168.0.255
        inet6 fe80::250:56ff:fe8a:e427  prefixlen 64  scopeid 0x20<link>
        ether 00:50:56:8a:e4:27  txqueuelen 1000  (Ethernet)
        RX packets 5483  bytes 993844 (970.5 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 427  bytes 32476 (31.7 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
GigabitEthernet 0
        flags=6211<UP,BROADCAST,RUNNING,SLAVE,MULTICAST>  mtu 1500
        RX packets 5479  bytes 993604 (970.3 KiB)
GigabitEthernet 1
        RX packets 4  bytes 240 (240.0 B)
        TX packets 0  bytes 0 (0.0 B)
2 REPLIES 2
Highlighted
VIP Advocate
  ipv6 enable
  shutdown
  ipv6 enable
ise02/admin# conf t
After a few minutes
  ipv6 enable
And
GigabitEthernet 0
GigabitEthernet 1
Beginner
Thank You Arne for quick reply, it works.
