Cisco ISE Pluse license consumption
munish.dhiman1
Hi ,
Could you please confirm  scenario below ? Cisco ISE with 5000 Base License  for 1000 Devices  (Non 802.1x Supported devices,Printer,IP phone etc. ) and 4000 Laptops .
1.Can i buy  only 100 Plus licenses to classify all the 1000 (Non 802.1x Supported  ) devices using profiling ?
2.If i MAB  only 100 (Non 802.1x) devices at a time and let the pulse license classify and put them in a group .and repeat the steps for remaining   900 devices .
3. Once the database with MAC of these 1000 devices  is build, move all the  Database to the a new group and apply authorization policy by using only base license .
Reason of doing this to save the Plus License expenses .
Can someone confirm it this works? Thanks a ton..
MD
2 Accepted Solutions
Jason Kunst
Working around the licensing is not supported or designed but you are likely to try, sounds right
I’m sure there’s many people who have tried this out there but is nothing documented as official support or write up from our Cisco side Besides that it sounds correct. Give it a shot.
Jason Kunst
Hi jason,
Thanks for your response, I am kinda looking for a confirmation on this approach. if someone had tried it or Cisco confirms.
Hi Jason,
Thanks for your response, I am kinda looking for a confirmation on this approach and understand of any loopholes if we do it in production. if someone had tried it or Cisco confirms.
