For production deployment issues, please contact the TAC!
We will not comment or assist with your TAC case in these forums.
Please see How to Ask the Community for Help for other best practices.
Question about SMTP Configuration. I have to configure SMTP Gateway to allow SMTP Reley from IP Addresses of ISE.
QUestion is: What IP Address should i use? Admin, MnT, PSN? or all of them?
What node is responsible of sending out messages via EMAIL?
Thank you
Solved! Go to Solution.
Please use the IP address of the Primary Admin Node (PAN).
-Tim
-Tim
Thank you
