ISE 2.6 Patch 1 is available! View the ISE 2.6 Release Notes and Download the Patch!
ISE 2.2 Patch 14 is available! View the ISE 2.2 Release Notes and Download the Patch!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
548
Highlighted
Beginner
Cisco ISE web redirect not working
Can anyone help with this. I have an open SSID doing MAC filtering to ISE with the following auth rules;
My devices is hitting correct rule for the unknown MAC but it is not redirecting me to the guest portal & is allowing me access in the associated VLAN assigned to the WebAuth policy.
Everyone's tags (4)
3 ACCEPTED SOLUTIONS
VIP Advocate RJI VIP Advocate
VIP Advocate
Re: Cisco ISE web redirect not working
Ok. Check the ACL on the WLC and ensure the case is the same as defined on ISE and spelling.
Check this page and double check the configuration of the WLC configuration.
VIP Advocate
Glad to hear it's working now. I haven't used Guest for a log time, but does this link do what you want? This is to configure approval request email to a sponsor.
Beginner
After applying the cert to the admin role & restarting ISE all portals on all browsers are now accepting the certificate. Seems strange that they didn't when we applied it to the portal role because that doesn't require a restart.
20 REPLIES 20
Beginner
Just to add, I can browse to the redirect link from the device.
VIP Advocate
When you access the link from the device is it via FQDN or IP address?....can the device resolve the dns hostname of the ISE PSN?
Can you confirm the redirect ACL been applied to the interface?...what is the output of "show authentication session interface Gi x" ?
What is the configuration of your called ACL_WEBAUTH_REDIRECT?
Beginner
Accessing the link works using the FQDN & the client can resolve this.
What interface would the ACL be applied to being this a wireless connection?
Below show the attribute of the Cisco_WebAuth profile but where to I find the configuration of the ACL_WEBAUTH_REDIRECT.
There is also a "!" withe the following note;
VIP Advocate
Sorry I mis-read the original post and assumed it was wired. Can you confirm the configuration of the ACL_WEBAUTH_REDIRECT ACL defined on the WLC? Can you check the WLC for the client session and confirm the redirect ACL is applied.
Beginner
It doesn't look like it is applying the ACL. Do I need to create the ACL on the WLC as well?
VIP Advocate
Beginner
Awesome thank you. It works. Wish I had this guide before.
I've another question now.
A guest theoretically could enter any details they like on the registration page to get access. Is there a way to verify them by email or any other methods? We sometimes have minors on site & they might need a different level of access or URL filtering, either way, for compliance we would have to be able to identify the users.
VIP Advocate
Beginner
Only issue is the web page only seems to work with IE or edge. Is there support for other browsers & mobile devices?
VIP Advocate
Do you get a certificate on the non MS browsers? If you are using an Internal CA then the IE/Edge browsers would automatically trust those certificates and not present a certificate error. Firefox/Chrome and a mobile browser would not trust the Internal CA unless specifically configured to do.
Beginner
We have imported the full certificate chain that has been signed by a CA authority & bound the original cert request. It has being used by the default portal certificate group and we can confirm in the browser when redirected that is is using this certificate but it is still saying it is not trusted.
VIP Advocate
Does your client computer have the QuoVadis EV SSL ICA G3 certificate in it's machine store?
Beginner
No it doesn't
VIP Advocate
That QuoVadis certificate needs to be imported to the computer trusted certificate store, otherwise the web browser will consider it untrusted and error.
