09-05-2019 10:07 AM
Hi Experts,
Hope everyone is busy and fine.. I have a very generic question about Cisco ISE. In case of 2000 user size with all logging and monitoring enabled if the primary ISE is down , how much time it will take to recover in the new VM with all Configuration data and Operational data.
Any timeline information is really appreciated.
Thanks in advance
V
Solved! Go to Solution.
09-08-2019 02:52 PM
If rebuilding the node is your only option then you're in for a journey. Hard to say - if you dedicate yourself to the task and you have all the information to bebuild the node, then 3 hours should be doable. Add 30 mins for patching.
Most of the time is spent waiting for ISE to do something (application restarts).
09-08-2019 02:52 PM
09-09-2019 01:12 PM
Thanks Arne. If you have issues in recovery and your production network is affected. Please call up TAC.
-Krishnan
