10-09-2017 06:45 AM
In 2.3, in my live logs I see a pretty constant stream of dynamic author failures and if you dig into them they are CoA Requests between the PSNs with the receiving PSN NAKing it. I think it is MAR cache sync causing the CoAs as I see this in the details:
acs:mar-cache-operation=query-entry, cts-pac-opaque=****
We aren't using MAR cache, and I don't have MAR cache distribution enabled.
I am just treating this as noise in the live logs, but wanted to know if I should be digging into this.
Thanks.
Solved! Go to Solution.
10-09-2017 06:56 AM
This is a known issue -- CSCve84667 -- and planned for 2.3 Patch 1.
10-09-2017 06:56 AM
10-09-2017 08:55 PM
Can you give a rough idea on when to expect Patch 1?
10-09-2017 10:12 PM
Sorry but we cannot comment on a release date in a public forum. It's taking more time as we are adding a couple of critical fixes.
04-08-2020 12:04 PM
06-18-2019 12:11 AM
Hi Paul,
Actually I have the reverse problem: mar cache distribution is enabled but apparentely not working. Since both TAC and my TAM are not able to provide me any useful troubleshooting tip might you please so kind to tell me how did you get the logs messages you indeed didn't expect?
MM
06-18-2019 04:26 AM
06-18-2019 04:36 AM
At the end I figured how to get the log messages I need setting aaa-runtime log at trace level.
Details here
M
