Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
217
Highlighted
Configure ISE 2.1 with MS SQL using ODBC - retrieve Group ID
I have a question regarding the use of ODBC in ISE 2.1 to retrieve Group IDs.
In ACS you can get the Result as well as the Group, but as described in this article this is only available in ACS 4.2
                http://www.cisco.com/c/en/us/support/docs/security/identity-services-engine-21/200544-Configure-ISE-2-1-with-MS-SQL-using-ODBC.html#anc8
If we want to retrieve GroupIDs for i.E. VLAN Assignment in an Authorization Rule we need to use a dedicated Store Procedure?
Do we improve the Group Retrival for the ISE to be similar like ACS?
BR,
Sven
Everyone's tags (4)
1 ACCEPTED SOLUTION
Advocate
Re: Configure ISE 2.1 with MS SQL using ODBC - retrieve Group ID
You can select retrieval of group and other attributes in ISE for use in Authorization Policy rule conditions.
/Craig
1 REPLY 1
Advocate
/Craig
