ISE 2.3 Patch 7 has been posted. This will be the last patch for the ISE 2.3 release!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
122
Highlighted
Console port ISE 3655 giving non-readable characters
When connecting directly to console on an ISE 3655, it is showing non-readable characters.
Customer is using Putty and baud rate is set to 9600, it is a new node, it has never worked before.
Please see error attached.
Can it be a hardware issue? Or is there something else we can check?20190805-123636487_Capture.JPG
Everyone's tags (3)
1 ACCEPTED SOLUTION
VIP Engager
Re: Console port ISE 3655 giving non-readable characters
You could have them try this.
To enable serial console in new 3615/3655/3695 appliances you need to disable Serial-over-LAN setting in CIMC:
demo-cimc# scope sol
demo-cimc /sol # show
Enabled Baud Rate(bps) Com Port SOL SSH Port
yes 115200 com0 2400
demo-cimc /sol # set enabled no
demo-cimc /sol *# commit
no 115200 com0 2400
https://community.cisco.com/t5/identity-services-engine-ise/do-the-new-ise-3600-series-appliances-support-serial-console/m-p/3903511#M29416
2 REPLIES 2
VIP Engager
no 115200 com0 2400
Thanks!
