02-20-2018 04:19 PM
I have an odd error when I query the guest types on my lab deployment running 2.3 patch 2.
https://10.89.80.34:9060/ers/config/guesttype
"ERSResponse": {
"operation": "GET-getAll-guesttype",
"messages": [
"type": "ERROR",
"code": "Conversion exception"
"link": {
"rel": "related",
"href": "https://10.89.80.34:9060/ers/config/guesttype",
"type": "application/xml"
I can make the same query without issue to a customer's deployment. Not sure what the conversion exception means. I can query other stuff from ISE via API (endpoints, DACLs, etc.). Does it mean I have a bad guest type of some sort?
Solved! Go to Solution.
02-20-2018 05:36 PM
I opened CSCvi07975 on the filter issue. Please wait for a couple of days before it externally visible.
If you get the same error again, please turn on debug on ers and check ise-psc.log and guest.log.
The API doc says,
CONVERSION_EXCEPTION | Occurs for some internal conversions and should be treated as INTERNAL_EXCEPTION |
02-20-2018 04:50 PM
Well I guessed it was something with the guest types it didn't like. I deleted all the custom ones I created, then the query worked. Then I rebuilt the guest types I wanted and it still works.
One oddity is that the filter by name doesn't appear to work.
https://10.89.80.34:9060/ers/config/guesttype?filter=name.eq.Guest_Daily
I have a guest type called Guest_Daily that the filter doesn't work. The call just returns all the guest types.
02-20-2018 05:36 PM
The API doc says,
