ISE 2.6 Patch 1 is available! View the ISE 2.6 Release Notes and Download the Patch!
ISE 2.2 Patch 14 is available! View the ISE 2.2 Release Notes and Download the Patch!
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
92
Highlighted
Custom error messages in guest / CWA portal
I have a need to return custom error messages to a user when they fail to pass through a CWA portal.
For instance, a user signs in and passes authentication, but doesn't have the proper AD group membership. Want error message to state "you're missing XXXX access".
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: Custom error messages in guest / CWA portal
You would need to direct them to a custom page built under customer portal files
https://www.cisco.com/c/en/us/td/docs/security/ise/2-2/admin_guide/b_ise_admin_guide_22/b_ise_admin_guide_22_chapter_010000.html#id_34829
if guest_flow and ADgroupX then redirect to authz profile with custom file redirect
Other customization examples under http://cs.co/ise-guest
There is no way dynamically to do this in the portal.
3 REPLIES 3
I'm not sure how ISE will be able to detect the group membership of the user, since this is purely a MAB+CWA authentication.  I'm going to play around in the lab today with it, but are you suggesting they'll hit a "default" portal, which will then dump the user into the guest_flow, re-parse the authz list, then redirect them to a second portal based on their group membership?
the only way to know the group is to have them login to the CWA portal and get a success then you can now key off that since a COA took place authz will know the info. You can say say if guest_flow and AD group.
take a look at the http://cs.co/ise-guest
ISE Guest Access Prescriptive Deployment Guide
