Custom .js embeded in ISE Guest Portal
Adrian Aron
Hello team,
I have a challenge with one of our projects, where we need to display the Guest associated MAC address in the form of a QR code. I added Support page to Guest AUP flow and I can see the associated Guest data there, but I failed to embed a proper JS, that reads the variable "MAC address" and converts it into a QR code picture and displays it on the Support page.
How can I get an example of this ?
Jason Kunst
Jason Kunst
Please check out this article.
ISE Portal Support Page MAC Address as a QR Code
Hy again Jason,
My code is pretty basic, embeds a .js function stored on ISE Custom repository, then calls a function to construct and display a QR code with the MAC address information of Guest user; The main issue I find now, is where I get the variable MAC address for each Guest session in ISE ? Now the QR code is using a static input to ensure that jscript is correct. The other issue is that ISE is parsing the script and moves <div> at the end of script and calls made in .js by ID no longer function.
<script type="text/javascript" src=":8443/qrcode.js"></script>
<div id="qrcode" style="width:100px; height:100px; margin-top:15px;"></div>
<script type="text/javascript">
var qrcode = new QRCode(document.getElementById("qrcode"), {
    width : 100,
    height : 100
function makeCode () {
    qrcode.makeCode("00:40:FE:2A:49:E0");
makeCode();
</script>
