06-04-2019 07:30 AM
Is there a way to disable default guest and sponsor portal ?
I am running nmap scan on ISE and port 8443 and 9002 corresponding to guest and sponsor portal are open.
I don't have guest use case so I am looking to close them but don't see an option.
Also tried disabling interfaces assigned to the portals but ISE needs atleast one interface assigned.
Solved! Go to Solution.
06-04-2019 08:11 AM
06-04-2019 08:11 AM
11-07-2023 03:12 PM - edited 11-07-2023 03:13 PM
I'm working on a trimmed down ISE deployment environment, where we don't need a lot of extra services, like for example the guest portal accounts and the ports you mentioned above. I would like to disable this service too. did you get anywhere with this? perhaps the newer versions of ISE allow for disabling? thx! Will
11-07-2023 07:29 PM
No, there is no feature enhancement in current versions of ISE to categorically turn off the Portals.
If you like, you can submit this suggestion via the Make a Wish page.
