Disable HSTS on ISE?
tuenoerg
hi all
One of my customers is facing problems on the sponsor portal when using Chrome browser.
Chrome stops and "complains" about HSTS.
Can we disable HSTS on ISE?
or - is this there another workaround?
ISE 2.3 patch 1 is used.
Br
Tue
hslai
No, this is not configurable in ISE.
Assuming Chrome stops due to the web portal is presenting the ISE server certificates for admin, the only workaround is to include the portal FQDNs in those certificates' SAN fields.
hslai
I have deployed sponsors portal using the same certificate that we use for Admin because it has wildcard SAN entry, but we use FQDN which does not explicitly exist in certificate (so we rely on wildcard). Due to HSTS both Chrome and Firefox report there's a problem with the certificate. In fact, the page loads fine on first attempt, but all consecutive attempts fail and certificate is blamed. What is the fix for this please?
Please check out this link for an answer... Hope this helps...
https://cisco-marketing.hosted.jivesoftware.com/thread/88180
@Bryan Byers The link you provided points to this very same conversation :)
