Register for the monthly ISE Webinars to learn about ISE configuration and deployment.
Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
1016
Highlighted
Does cisco ise also able to send out email notification if a posture condition has failed ?
I believe there is a schedule report that can be run ie: posture assessment by endpoint and there is notification send whe  the report is executed.
The question is is there a way to be immediately notified if an endpoint fails posture checks by ISE ?  And if so what information is contained in the alert and what type of alert is provided by ise ?
I suspect there may be a way that some siem may be able to provide this type of alert .. looking for native to ise.
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: Does cisco ise also able to send out email notification if a posture condition has failed ?
ISE does support email notification and you can find tab in the Alarm Settings section as a tab.
For complete alarm list you can look at the Alarm configuration tab. AFAIK we do not have an alarm for posture failure. Please work with your Cisco SE to open an enhancement if there is a need for it and let them know the context.
-Krishnan
3 REPLIES 3
All ISE Alerts can be seen by logging in to ISE and navigating to Administration > System > Settings > Alarm Settings.  If the alarm you want is not there, then it cannot be done at this point.
-Krishnan
Beginner
It appears that you can only select one of the pre-canned alarms in ISE....is there a way to select multiple alarms to send email alerts on?
