07-15-2019 08:20 AM
Company A and B are merged with permanent Network Interconnect, i have a PSN with an overlap IP which i am trying to register ( the fqqdn abc.corp.xyz.com resolves to the real IP and NATTD IP ) , the initial-registration is going through fine but replication or the final registration is failing.
So, what are my options here to get this work apart from RE-IPin the PSN?
Awaiting your response.
Atif
Solved! Go to Solution.
07-15-2019 06:34 PM
Nope, as you already found. All ISE nodes need to able to communicate using their real IP addresses.
07-15-2019 06:34 PM
