11-16-2017 04:01 AM
Hi all,
I´m looking for some more details on the DXL and PxGrid integration.
For now - all I found is :
Can anyone help me find more tech details?
Br
Tue
11-16-2017 07:21 AM
Since this is a pxGrid integration, most of the configuration will be done on the McAfee side. You may need to reach out to them to provide specific documentation.
According to this paper, an Integration Pattern Engine (IPE) from McAfee may be needed:
https://www.mcafee.com/au/resources/solution-briefs/sb-cisco-dxl.pdf
11-16-2017 07:28 AM
Thanks a lot.
I´ll ask the customer to reach out to McAfee too. Do you know of any actually using this ?
best regards
Tue
11-16-2017 07:30 AM
I have asked our pxgrid SME to also look at this
11-16-2017 10:06 AM
This is similar to Cisco ISE pxGrid and McAfee OpenDXL integration
