Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
116
DXL and PxGrid
Hi all,
I´m looking for some more details on the DXL and PxGrid integration.
For now - all I found is :
https://www.cisco.com/c/dam/m/en_us/products/security/technical-alliance-partners/core/assets/pxgrid-mcafee-opendxl-inte…
Can anyone help me find more tech details?
Br
Tue
4 REPLIES 4
Re: DXL and PxGrid
Since this is a pxGrid integration, most of the configuration will be done on the McAfee side.  You may need to reach out to them to provide specific documentation.
According to this paper, an Integration Pattern Engine (IPE) from McAfee may be needed:
https://www.mcafee.com/au/resources/solution-briefs/sb-cisco-dxl.pdf
Highlighted
Re: DXL and PxGrid
Thanks a lot.
I´ll ask the customer to reach out to McAfee too. Do you know of any actually using this ?
best regards
Tue
Re: DXL and PxGrid
I have asked our pxgrid SME to also look at this
Re: DXL and PxGrid
