04-30-2018 06:58 AM
I'm not able to find a current document that shows an example of configuring a Cisco WLC with ISE. Specifically how to configure each side, ISE and WLC, for dynamic VLANs.
There is this - circa 2012 using ACS:
Dynamic VLAN Assignment with RADIUS Server and Wireless LAN Controller Configuration Example - Cisco
Solved! Go to Solution.
04-30-2018 03:01 PM
There are many ways to effectively change the VLAN/WLAN for wireless user. In addition to IETF tunnel attributes as
discussed in the original guide referenced, ISE can return other vendor specific attributes (in this case Aerspace).
See ISE Network Access Attributes
Craig
04-30-2018 09:51 AM
Hi danda,
You can find a lot of guide regarding ISE design and deployment here:
ISE Design & Integration Guides
For specific WLC & ISE integration, here is the guide:
How To: Universal Wireless Controller (WLC) Configuration for ISE
I hope you can find it useful.
Eduardo
04-30-2018 03:01 PM
Craig
06-07-2018 04:42 AM
Did you get this working?
I've been working trying to get this to work, but with no avail.
Be interested to see how you completed this
Cheers
