07-10-2019 07:28 PM
Hi Team,
I have 1000+ users who need 802.1x to be enabled. (Windows, Ubuntu, Mac Os). We have configured the CISCO ISE and wonder is there's any way we can use a batch file to deploy. We can ask user to download and run the batch file.
Have anyone done this before, or how to enable 802.1x on 1000+ users without doing it manually? (Users are not domain connected)
Thanks in advanced.
#ciscoise #802.1x #nac
Solved! Go to Solution.
07-21-2019 09:04 AM
Many organizations use a MDM to do this. If you consider that, please check with the MDM vendors.
ISE BYOD can help with MS Windows, Apple iOS, and macOS, but not Ubuntu.
If you want to do it yourself...
For Windows, this one looks interesting — Configuring 802.1x Authentication for Windows Deployment - A Square Dozen
For Apple macOS and iOS, create a .mobileconfig file using Apple Configurator or similar tool and then distribute it.
For Ubuntu, see ubuntu - How to automatically apply wpa_supplicant configuration? - Unix & Linux Stack Exchange
07-11-2019 12:10 AM
07-21-2019 08:13 AM
Thank you, the issue is im only involved with enabling it on client side. Switches are configured by a separate department. So I wonder is there's a script that can be used for Windows/Ubuntu/Mac OS.
07-21-2019 09:04 AM
07-11-2019 05:34 AM
07-21-2019 08:15 AM
Hi Mike,
These are not domain connected devices.
