Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
353
Beginner
Encryption for TACACS+ user passwords inside ISE2.2's Internal Identity Store
Hi All,
I'll just like to confirm that my understanding of how encryption is currently done for TACACS+ users in ISE 2.2 Internal Identity Store:
With reference to this link: http://pmbuwiki.cisco.com/Products/ISE/Technical/Security#How_is_information_encrypted_in_ISE_for_local_Identity_Storage…
As mentioned in the document above, only the users' passwords (and not the rest of the fields/columns) in the database are hashed using SHA256 and stored without any cryptography "salt" component? May I know what is the recommended approach if customer has an audit compliance requirement that users' passwords have to be hashed and "salted" before kept on any DB?
Best Regards,
Jimmy
Everyone's tags (3)
4 REPLIES 4
Highlighted
Beginner
Re: Encryption for TACACS+ user passwords inside ISE2.2's Internal Identity Store
Just to add on, I've also found this thread: https://cisco.jiveon.com/thread/134207
This kind of adds on additional information to the previous document.
However, it still says that non ISE-admin users' passwords are not salted prior to hashing with the AES128.
May I know is this considered acceptable for TACACS+ users' passwords?
Best Regards
Enable passwords are stored the same as regular passwords. Please contact our PM if you have additional requirements.
Beginner
Thanks for response. Appreciate if you could also point me in the right direction to the PM for such matters?
I just emailed you separately on this.
