Field Customization of My device portal
iurikura
Hi Expert,
Could you please confirm that can we customize (add/remove) the fields end-user should input at My device portal .
By default there are three fields; "Device Name", "Device ID," and "Description".
Thank you,
Itaru
Jason Kunst
There is no direct way to remove in the UI besides using JavaScript
Under http://cs.co/ise-community
Byod section there are some examples
There is no way to add additional fields
If you need more functionality please reach out through sales channel to the ISE-PM team
Jason Kunst
Hi Jason,
Thank you so much for the reply.
I understood Javascript is available to customize something but there is no option to add fields.
https://communities.cisco.com/message/208100#208100
Thank you,
Itaru
Adding fields would not be easy as they would need a way to persist to the backend. I would suggest to discuss with our PM team for an enhancement.
IF your customer requires this they could also use the API to uodate Fields not included in my devices portal
they would basically create create their own portal
