Fortigate authorization with ISE
nimmi.phasil
Anyone has done Fortigate firewall radius authorization with ISE ?
What are the Radius attributes ? I tried with
Fortinet-Group-Name
Fortinet-Access-Profile ; but not successful
Nimmi
thomas
Nimmi,
You will need to consult the Fortinet Firewall documentation for the required attributes for a successful authorization.
We have not done any explicit testing with Fortinet products but because ISE supports any standard RADIUS communications with Vendor Specific Attributes (VSAs) it should work. I searched for "fortinet radius authorization attributes" and found the Fortinet Knowledge Base article Fortinet RADIUS vendor-specific attributes (VSAs) which lists the following VSAs:
# Fortinet VSAs
VENDOR Fortinet 12356
BEGIN-VENDOR Fortinet
ATTRIBUTE Fortinet-Group-Name        1 string
ATTRIBUTE Fortinet-Client-IP-Address 2 ipaddr
ATTRIBUTE Fortinet-Vdom-Name         3 string
ATTRIBUTE Fortinet-Access-Profile    6 string
# Integer Translations
END-VENDOR Fortinet
I have also attached the above text as a plain text file named Fortinet_VSAs.txt for you to import into ISE.
To import these attributes into ISE:
1) Navigate to Policy > Policy Elements > Dictionaries
2) In the Dictionaries left panel, choose System > RADIUS > RADIUS Vendors
3) You should see a list of RADIUS Vendors that does not include Fortinet
4) Select Import
5) Browse... for the Fortinet_VSAs.txt file then click the Import button and acknowledge the dialog to import the file.
6) You should now see Fortinet in the RADIUS Vendors list:
and all of the Fortinet attributes listed under the Dictionary Attributes tab:
So you can use these attributes in your ISE Authorization Profiles per the Fortinet requirements / recommendations.
11 Replies 11
thomas
Nimmi,
# Fortinet VSAs
END-VENDOR Fortinet
4) Select Import
Hi Thomas,
I know this is an old post but I wonder if you can provide me with the rest of the configuration on ISE so I can Authenticate admin login to Fortigate.
Gamal Mohamed
Fortigate is not our product so you are best to consult Fortigate support, as Thomas suggested.
SSL VPN with RADIUS authentication from the Fortinet Cookbook might help.
Hi Hslai,
Many thanks for your reply.
But can you help me configure the ISE part like authentication and authorization rules and any necessary configuration?
Have you tried configuring authentication and authorization without success? If so, maybe you can share your configuration and logs so the community can try to help you.
George
We do not test this 3rd party device so can't tell how it working exactly.
Remote Admin login with Radius selecting admin access account profile looks like it allows using RADIUS to perform device admin so ...
  1. Import or define the RADIUS vendor dictionary for Fortigate, as Thomas showed
  2. Define an allowed-protocol set or use the existing one to match what configured in Fortigate
  3. Define an authorization profile that returns the required vendor attributes. An example shown in the screenshotScreen Shot 2017-11-14 at 12.01.38 PM.png
  4. Define a Network Device group for Fortigate
  5. Define a Network Device for Fortigate and specify (4) as its group
  6. Define some internal users or add external ID sources and/or define an ID source sequence
  7. Create a policy set to condition on (4)
  8. In the default authentication policy rule, use (6) as the ID source. Or, you may create additional rules as needed.
  9. In the default authorization policy rule, use (3) as the result. Or, you may create additional rules as needed.
Good luck!
Hi Hslai,
I really appreciate your help.
It works
Gamal Mohamed
I am glad that you are able to get it working. If you have some time, please contribute it as a how-to doc in our community and provide details, such as the product versions you tested.
Hola Gamal Mohamed,
Tienes algun documento de el proceso que realizaste para integrar fortinet?
Podrias compartilo?
Gracias.
Saludos.
Hi Hslai
Can you help with the attributes for the authorization profile, these attributes where they were obtained? because i configure the similar situation.
Thanks for your help.
Regards.
Please follow Comment 1. and then Comment 6.
