Guest User Group
nikhilcherian
Level 5
Level 5
Dear Community,
When I allow Guest Users for selft registration, Can I controller the credentials send to them are created in a specific Identity Group. I know that I can control the end point to be added in a specific Endpoint Group, But I want to know if I can create a group for the user credentials
Nikhil
hslai
Sure, each guest type is mapped to a user id group and one of them can be associated with the self-registration form.
Jason Kunst
No the only thing you can do is use a Guest Type
Guest types can be used to different user access if needed
What is your end goal?
hslai
I was looking for some quick ways, to find out which are the usernames created for the guest users, who did the self-registration
Nikhil
It’s not clear if you’re allset? Please reword your question if you’re still in need of assistance
