Hardware upgrade from 3495 to 3595
tmatzeu12
Hello guys,
My customer wants to perform a hardware upgrade from 3495 to 3595 (PAN + MnT), version 2.0.1.
Can I backup the config from the 3495 and restore it to the 3595?
Thomas.
Timothy Abbott
Hi Thomas,
Yes, you can.  Please see the Back up and Restore Operations section of the admin guide for instructions on how to do it.
Cisco Identity Services Engine Administrator Guide, Release 2.0 - Backup and Restore Operations [Cisco Identity Service…
-Tim
Timothy Abbott
Hi Thomas,
-Tim
Thanks Tim!
Charlie Moreton
Yes, you can.  Two important things to remember:
A regular backup does not contain the Certificate Store and Private Keys.  Follow the steps at the link below to back these up and then restore them on the new Appliance:
Export Certificates and Private Keys
You can re-host your licenses onto the new SNS-3595 appliances quickly and easily.  Follow the steps here:
Re-Host Licenses
Though these steps only need to be completed on the Primary Admin Node (PAN), you need the UDI information from the Secondary Admin Node to properly Re-Host the Licenses.
Thanks Charles!
