Hiding a button from the portal
sampathss
Is there a way to hide the button from the portal?
There is no option to use the javascript for a button field under page customization.
This is on the Client Provisioning portal. Trying to see if the "Start" button can be hidden, so that the user won't click the same.
16 Replies 16
Hello Serhii,
I would like to do same configuration. Could you share the video again? It´s not available.
Best Regards,
Daniel Stefani
Hi Daniel,
I didn't save that recording, but I can provide you manual how it possible:
1. Open "Portal page customization" of your portal
2. Select "Advanced customization" and choose "Export/Import theme"
3. Export theme and insert style (if it is for the same option and for the same portal)
4. Import theme, set new name and save
5. Switch to new theme and save the portal
6. Use "Portal test URL"
