How did you manage Entrust with ISE 2.2 ?
arane0001
Entrust IDG token is not a Cisco product so I am not certain how ISE can integrate with it. I found some hits by search "entrust IDG RADIUS" so it seems Entrust Identity Guard server has a RADIUS interface. Please give more details on the incompatibility info provided by Entrust support.
5 Replies 5
arane0001
Sorry about that ....we are having trouble making Entrust IDG token to work with Cisco ISE 2.2 for VPN authentication using Anyconnect client.....support from Cisco and Entrust landed saying Entrust and Cisco ISE are not compatible
is your Entrust being used for the same implementation as a token ?
So you called the TAC and they said not supported?
My Cisco SME told me
