Choose one of the topics below to view our ISE Resources to help you on your journey with ISE
Please see How to Ask the Community for Help for other best practices.
313
How do I clear the anomalous behavior flag from endpoints after resolving the anomalous behavior without deleting the endpoint?
Hi team, as the question title stated, how do I clear this flag without resorting to endpoint deletion.
Sudhir
Everyone's tags (2)
1 ACCEPTED SOLUTION
Highlighted
Advocate
Re: How do I clear the anomalous behavior flag from endpoints after resolving the anomalous behavior without deleting the endpoint?
Yes, but highly recommend you have Cisco account team send request to Kevin Gagnon (kegagnon) to submit customer name and business impact to assist with feature prioritization.
6 REPLIES 6
Highlighted
looking at this guide it seems like the only way to clear is to remove the endpoint
Configure Anomalous Endpoint Detection and Enforcement on ISE 2.2 - Cisco
will ask the SME
Highlighted
Thanks for the assistance, Jason.
Cheers,
Sudhir
Highlighted
Advocate
Correct.  Currently Delete endpoint is only option.  You could also export/delete/import via file or API to re-add endpoint so some of the key endpoint attributes like ID group, Guest values, Portal User, MDM, and custom attributes are recovered.  Profiling info will be dynamically relearned.
Highlighted
Is there an existing enhancement request to provide a clearing function other than deletion for this? If not, we will open one.
Highlighted
Advocate
Highlighted
Alright, will do. Thanks!
Cheers,
Sudhir
