02-21-2017 08:04 AM
I have a full distributed deployment with separated personas in SNS3595 appliances. They are running 2.0.1 (Patch 1).
I would like to know how many profiler events by second are supported by the SNS 3595 appliances? I couldn't find the number on the datasheet.
Víctor.
Solved! Go to Solution.
02-22-2017 07:11 AM
We do not have public facing scale number around the profiler performance. It depends on the probe type, but in general in the range of 200 - 250 per second for the SNS 3595.
02-22-2017 07:11 AM
